Gas Tank EG Civic..
Discussion in 'HYBRID -> EG-EK / DC' started by FastRCars, May 25, 2005.
  1. FastRCars
    FastRCars Member
    I got this -94 Civic with the D13 non-vtec engine , i am installing a 255L Walbro pump and need of course a return fuel line , is there or is there not a return fuel connection on my gas tank?
    EDIT: Im putting down a Jspec H22 engine in to it..
    pls see attached file:
    PICTURE OF GAS TANK
  2. 96CIVICLS
    96CIVICLS Senior Member
    THATS THE EVAP SYSTEM THE BYPASS SELIOND THATS HOOKED TO THE FUEL RETURN THATS WHY ITS CALLED A BYPASS SELNOID. HOPE THIS HELPS
    YA BOY STEVEO
  3. FastRCars
    FastRCars Member
    Hm i dont get it?... :blink:
  4. jdmlovingcrx
    jdmlovingcrx Member
    cincinnati
    evap ownes you you tamper with that and mess up you are in for a head ache
  5. pissedoffsol
    if your car does have a return line, look for a copper/brass tube sticking up from the firewall, just to the left (if standing in front of the car) of the brake booster/master, and down a little ways. thats where it would be if you have one.
    i know next to nothing about those d13 motors/cars, as we don't have any in the states.
  6. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    I should have looked today, we were at the yard and there's two of them there. I'll see if I can make it tomorrow.
  7. FastRCars
    FastRCars Member
    Great! pls do so..:)
    Thanx guys!
    It looks though like i´ll using a new tank from the 160Hp Vtec Civic and draw new fuel lines , it seems to be the most easy way to solve the problem..im using a walbro "in" tank fuel pump.
    // Jonas
  8. FastRCars
    FastRCars Member
  9. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    we have to sign in/up, and sinces its in a diffrent language, it might be hard. Just link them here using [IMG-] http//url.com/pic34r30[/IMG-] and just leave out the - sign in the tags.
  10. FastRCars
    FastRCars Member
  11. jdmlovingcrx
    jdmlovingcrx Member
    cincinnati
    the "filter" is the charcole canaster
    1&2 look like abs or something number 3 i have no clue
    the ? mark is your heater hose
    top arrow is your evap purge valve
  12. FastRCars
    FastRCars Member
    1&2 r fuel lines..
  13. 96CIVICLS
    Ill get a digram of this and show you let me look for it and ill help the best i can.
    ya boy steveo
  14. FastRCars
    FastRCars Member
    :worthy:
    Thanx...
  15. xj0hnx
    C.C.TX.
    Number 2 is your fuel feed pipe and goes to the fuel filter, number 1 is your fuel return pipe and it goes to the FPR.
  16. xj0hnx
    C.C.TX.
    On the US model, number 2 is a hardline, as you can see in this pic....
  17. FastRCars
    FastRCars Member
    So..i got a return pipe? FPR?..u know this is a non injected car , it runs with a carburator as stock..D13 (1,3L non vtec) something is the model of the engine..
  18. thr33niL
    thr33niL Member
    While ur on the subject, where does the EVAP Purge valve usually run to? I had one originally on my 95 civ but there isnt one on the B18 fitting that came with my swap. It was a pain to get off so I left the cap with evap purge on and capped it off since the B18 seemed to not use it (did I screw up?).
    Dont mean to hijack, just this one question..
    :ph34r:
  19. xj0hnx
    C.C.TX.
    Just telling you what the lines are according to the US model, and what you're going to be needing to put in another one. The yard has been closed, so I haven't been able to really inpect another one of these.
  20. FastRCars
    FastRCars Member
    Ah great...)
