Gasket Sets?
Discussion in 'Engine Building' started by Slimtadder, Jan 2, 2003.
  1. Slimtadder
    Slimtadder Senior Member
    Lake Havasu City, AZ.
    Are there any company's I can order like a rebuild kit or gasket kit for a B16?
    Thanks
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    http://www.hondaautomotiveparts.com
    Honda makes somthing like three gasket sets. When you buy all three it replaces every gasket in the engine.
  3. cws13
    cws13 Senior Member
    Athens,GA
    Stay with OEM gaskets, you'll find cheaper stuff out there--but it will cost you later.
  4. BOTTLE FED B18
    BOTTLE FED B18 Junior Member
    Also with honda/acura motors you have to use certain colored bearings. If you look on the edge of the block under the oil pan ,on the tranny side, rear of motor <firewall side>. Sorry hard to explain without pointing at it. There will be five letters, example (DDBCC). These are the color codes for main bearings. If you still have the stock bearings , there half circles on the thin edge , there will be a colored line example( BLACK,GREEN, or BROWN) they all may be the same or all different, knowing these before you go to the dealership will really help trust me. AS far as gasket kits go factory is probably better ,but NAPA also has nice kits. Good luck
  5. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    www.inlinefour.com has OEM gasket kits.
  6. BOTTLE FED B18
    To 92B16vX , Your car brings back memories. I had a 92B18vX. I loved that car.
  7. xj0hnx
    C.C.TX.
  8. pissedoffsol
  9. xj0hnx
    C.C.TX.
    Some of the stuff they have is a lot less than other places.I'm not defending some of the prices are just crazy,but I saved about 200 bucks over most other places I checked on the stuff I ordered.
