gauge cluster not working
frosty
i just got finished with an LS swap, and the cluster worked the first couple times i started it and now nothing but the lights work... the tach, fuel gauge, and temp gauge just quit working. i checked all the fuses and grounds, unplugged and re plugged the clips on the fuse box, same thing with the plugs on the gauge cluster, and i can't get anything to work. has anyone had this problem before?
does the cluster have a power source other than the fuse for the lights? or does anyone know if the cluster has more than one ground?
