gauge cluster question
delsol88
Blinker Fluid Specialist
im wanting to put a b16 motor in my 1995 del sol. it has the d16z6 in it right now with the 7200 rpm redline cluster. my question is, will that cluster work when i drop the b16. if it does work how badly would my tach be off?
so basically what will happen is the needle will run past 8k? and 8k on my tach will be 8k on my motor???
yes, if you're running the correct ecu, rev it all the way to fuel cut, which should be 8200 rpm's and make sure it says that on the tach
