Gauges.
Discussion in 'HYBRID -> EG-EK / DC' started by JBHonda, Jan 7, 2003.
  1. JBHonda
    JBHonda Member
    Venice, Florida
    ive got a D series motor in a 95 Civic LX. how do i put a oil preasure gauge in the block? i dont want to take the stock sensor out and set off my check engine light. where do I put the sending unit?
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    You can put a T where the stock sensor is and run both the sending unit and the stock sensor off that T.
  3. JBHonda
    JBHonda Member
    Venice, Florida
    what does the stock sending unit look like and where is it located on the block?
  4. lsvtec
    On my 93 LS it looks like a 1 wire sensor with a rubber boot over it. If you are standing in front of the car bending over the engine it is below the oil filter and a little to the right.
  5. JBHonda
    JBHonda Member
    Venice, Florida
    is your oil filter on the back like mine?
  6. lsvtec
    All B, D, F, and H series FWD Honda engines have the oil filter on the back of the block. So yes.
  7. JBHonda
    JBHonda Member
    Venice, Florida
    ok well then ill get one . do you recomend me getting one? I mean the engine is getting old and i want to make sure it has good oil preasure. Thx
  8. lsvtec
    If you plan on boosting or doing a head swap then they are a good idea, otherwise your oil light will come on if the engine can't maintain the oil pressure it needs.
  9. JBHonda
    JBHonda Member
    Venice, Florida
    Yeah the thing is that my light has been coming on a lot. (every week) burning a lot of oil. i just need to keep a eye on it
  10. lsvtec
    Then yeah, add one. It certainly can't hurt.
  11. JBHonda
    JBHonda Member
    Venice, Florida
