GE Headgasket issue
Discussion in 'Engine Building' started by 94CivicSlow, Jun 23, 2005.
  1. 94CivicSlow
    94CivicSlow Senior Member
    B0ST0N
    Well I got my golden eagle ls vtec kit and it came with a ****-p30**** headgasket. Isnt that a b16 headgasket?
    Well... The water passages and so forth dont like up at all. The cyclinders do but thats about it. Im no idiot, this thing looks way off and will leak. Its an oem honda p30 headgasket.
    I thought it should be a pr4 gasket. Maybe Im wrong.
    Is anyone familiar with this problem, or heard of it? I can take pics if no one knows what i mean.
    The gasket is not upside down. It says "UP" etched in to it.
  2. 94CivicSlow
    B0ST0N
    I was right. Those SOBs sent me a GSR/B16 headgasket
    Part # 12251 P30 004 Fit's B16A , B18 (GSR) & B18C5 Type R
    I need:
    Part # 06110 PR4 030 non-vtec LS Head Gasket
    Anyone else ever have this problem? Slackers For 250$ they better come to my crib and bring me the right gasket!!
  3. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    When I bought a gasket from them it was like $80....
  4. 94CivicSlow
    B0ST0N
    250 shipped was the ls vtec kit which includes the wrong oem honda gasket.
  5. sohcslammer
    sohcslammer Senior Member
    Bay Area
    Sux. That's why I use SCE. :(
    (I have been hearing more and more negative remarks about GE lately........ Am I the only one????) :huh:
  6. civicious
    Houston, TX
    Oh, you bought the whole kit.
    There's like 8 different kits, the only difference being the headgasket size/model. You sure you ordered the right one? If you didn't open/use the gasket, you should have no problem exchanging it...Vince has been really cool and helpful every time I've called. When I built the B20 a while back, I accidentally ordered an 81mm instead of an 84.5mm gasket. I just called, sent them the 81 back, and within the week had the right gasket in.
  7. pissedoffsol
    if you're going ls/vtec, you want a vtec head gasket... not an ls one.
  8. sohcslammer
    Bay Area
    Incorrect Brian. You want an LS headgasket. :tisk:
  9. civicious
    Houston, TX
    :werd:
  10. 94CivicSlow
    B0ST0N
    No, hes right. I called Golden Eagle myself. They dont ship the LS headgaskets and dont reccomend using them because you would need to shave a rivet and using the vtec headgaskets more of the water holes oil holes etc line up properly. You can call them and they will tell you, although you want to use the ls one cause of the block, you should use a vtec one and when you buy their kit unless you specify otherwise, it comes with a p30 B16 headgasket.
  11. sohcslammer
    Bay Area
    I dissagre with golden eagle. I had my motor built by a shop that does hundreds of hondas and ls/vtecs. I also spoke with SCE about it, and c-speed recomends matching the headgasket to the block....
  12. pissedoffsol
    :shrug:
    i guess it goes both ways. IMO, its better to have the holes on the head line up. lol
  13. sohcslammer
    Bay Area
    :shrug2:
    WTF? How can that be? One side says "Definetly use the LS headgasket"
    The other side says "Oh,no! Don't use the LS gasket, use VTEC one!"
    :angry:
    If I used the wrong gasket I'ma gonna be REALLY pissed of. <_<
    Pissedofsohcslammer. :wallbash:
    NEED MORE OPINIONS!!!!!!
    Golden Eagle = VTEC
    C-Speed Racing = LS
    Hondaswap Resouces = LS
    Hondaswap Owner = VTEC
    :ph34r:
  14. pissedoffsol
    don't take my word for it- i never built one.
  15. civicious
    Houston, TX
    I used a non-vtec gasket on the B20, and it didn't have any headgasket problems....
    Granted, it had OTHER problems....but nothing relating to the headgasket...
  16. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    LS Head Gasket says me :p
  17. integraslut78
    KiLLa kALi
    B said he goes both ways :lol: :lol: :lol:
  18. sohcslammer
    Bay Area
    :lmao:
    Yeah, I talked to a few people and apparently you can use either headgasket depending on how you line up the dowel pins. So.... we are all right. :blink:
  19. 94CivicSlow
    B0ST0N
    Yea but if you use the LS gasket there ends up being a rivet that you should machine or it could leak..
    Thats what golden eagle says. They have a comment on everything and they will tell you about how T'ing off the oil pressure switch is the wrong way to do it cause it could cause stress and the T can crack, and the fact that its not filtered oil going to the head
    The guys over there are pretty intelligent so I trust them that they did their homework. THey said they sell 60 ls/b20/vtec kits and never got one complaint about the headgasket being incorrect fitment
  20. pissedoffsol
    they've sold a lot more than 60 of those things... lol
