Gear Boxes
Discussion in 'Engine Building' started by richie_vei, Feb 12, 2003.
  1. richie_vei
    richie_vei Member
    ive just bought a b16a2 n found out today the gear box has a massive crack in it, so i now need a new 1 what boxes can i use on it ive heard i could use integra type r but havent got a clue on what i can and cant use please help me
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    I would call the company that sold that to you and demand they give you a new tranny. A crack could cause massive headachs in the future. Yes the ITR tranny will work with it. You can use any B-series hydraulic tranny.
  3. richie_vei
    richie_vei Member
    the scrap yard said enigne was sold as seen, and its not just cracked its got a big hole in it, i can get a hold of an integra Type R box with LSD
  4. richie_vei
    richie_vei Member
    people are telling me over here that a integra box wont fit a b16a2 is this true
  5. E_SolSi
  6. pissedoffsol
    yup. all 94+ b-series trannys with the exception of the crv, are identical in physical shape/size/mounting/axel position/clutch, flywheel space/ and so forth
  7. cws13
    cws13 Senior Member
    Athens,GA
    I've never thought of this...but does that mean he could use, say an LS case for his b16 tranny internals if need be. Outside of mainshaft, do the shiftforks match etc...
  8. pissedoffsol
    internals are differnt to some extent.
    im not sure about the forks, but for example, the fdr means you can't or can use an lsd made for a different size fdr, and so on. so it really depends once you get inside
