gear indicator?
Discussion in 'ECU's, Electronics, and Tuning' started by sinezter, Jun 22, 2008.
  1. sinezter
    sinezter New Member
    hi i was wondering if anybody knows where can i get a digital gear indicator for my 89 honda civic? i can only find them for bikes, and they are small. and if there is any how do you connect them?
    thanksn for any help
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    I believe there's no drop-in indicator for H-pattern transmissions. Motorcycles have sequential transmissions.
  3. efhondakid
    Akron-Canton, Ohio
    What do you want one for?
  4. phyregod
    phyregod !!YTINASNI
    Central Texas
    Look at the top of your shifter knob.
  5. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    It would have to guess based on rpm and mph readings. Exactly what hondata does. It would take something semi 'custom'. No wire you can just splice into for say, like a tach.
  6. phyregod
    phyregod !!YTINASNI
    Central Texas
    I've seen drag racing tachs that had gear indicators on em..
    But why? You should just know what gear you're in.. get to know your car! If its a stick, then its the gear you put it in, if its an auto, count the shifts up and down.. It'll soon become automatic for you to just "know".
  7. George777
    George777 ^^ Likes Bewbies
    With your mom
    Unless maybe he's teaching someone else to drive? I had a rough time teaching some people how to drive stick--They just couldn't figure out which gear they were in without looking down and shifting the entire time...
  8. phyregod
    phyregod !!YTINASNI
    Central Texas
    ?? Perhaps an 18 wheeler with 2 shift knobs or something..
  9. efhondakid
    Akron-Canton, Ohio
    Hell yes, 20 forward gears FTW!
  10. K2e2vin
    Raleigh, NC
    That's true. I normally drive a 5 speed and when I hopped in a 6spd and 4spd it was no problem at all.
  11. awptickes
    MD
    Depending on what you're looking for.....
    Hondata s300 has a gear indicator. It's calculated by transmission ratios, RPM, and ground speed.
