gear oil
Discussion in 'General Tech and Maintenance' started by SolidDreamz, Jun 25, 2005.
  1. SolidDreamz
    SolidDreamz Senior Member
    va beach,pa,oh
    I've decided to change the gear oil in the tranny cuz i dont know when it was last changed and car has 60,000 miles on 00 gs-r i got 2mths ago.
    Shifting doesnt seem as smooth as should be, no grinds or what not but was wondering if i should just use factory recomended or something better? Thanks!
  2. kyleirwin
    kyleirwin Retired OG
    Vegas
    it's commonly agreed upon that honda MTF (manual transmission fluid) is the best for your tranny. you can pick it up at any dealer. off the top of my head i believe it takes 2.1 qts.
  3. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    Which means you have to buy 3 quarts right? Soon ill be switching to that, just once i get it on the road and get some money (friday) ill switch over from 5w30, so it's definately 2.1 Quarts? I drained the trans once and put new 5w30 in it for the time being.
  4. wanderinman
    wanderinman Senior Member
    Raleigh, NC
    I put Redline MTF in my LS's tranny and it was like a whole new transmission, just my input
    EDIT: 5W30 is a motor oil, and to the best of my knowledge should be substantially too thin for your transmission. I know my Toyota's manual took 85Wsomethingorother when I changed out the fluids. Somebody correct me if I'm wrong, but I would get that 5W30 out as soon as possible.
  5. VTECPOWER
    Winchester, VA
    they say 5w30 oil is the closest to honda mtf as anything else and it's ok to run it, obviously honda mtf is better.
  6. wanderinman
    Raleigh, NC
    Good stuff... now I know, and knowing is half the battle.
  7. kyleirwin
    Vegas
    i'm currently running 2 qts of stright 30 weight oil in my tranny. not sure if/when i'll switch to honda mtf :shrug2: .
  8. SolidDreamz
    va beach,pa,oh
  9. phyregod
    phyregod !!YTINASNI
    Central Texas
    I think chilton reccomends, if you cannot get honda mtf, that you use 10w30... I think....
  10. Taco15
    Tallahassee Fl
    thats what i was told
  11. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    I really like GM syncomesh MTF with friction modifiers. Really good stuff. You can buy it at any GM dealer's parts counter, or you can use Penzoil Syncromesh MTF which is the same part number as the GM stuff (as penzoil makes it for GM) and can be picked up at any autozone for 5 a qt.
  12. VTECPOWER
    Winchester, VA
    Honda MTF seems to be a very light oil, and it's only $3.85 at my local honda dealership.
  13. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Yea I'm using the Pennzoil one, it helped make shifting smoother on my 17yr 230000mile transmission :) Also, the Texaco is the same as the Pennzoil and GM from what ive read on the Oil forums.
  14. Taco15
    Tallahassee Fl
    can you use all gm syncromesh? I mean i put one bottle of syncromesh and the rest was valvoline gear oil.
  15. nfn15037
    nfn15037 Senior Member
    Which is exactly why using 90 wt Redline is a bad idea......
  16. asmallsol
    yes you can. Remember though to get GM syncromesh WITH FRICTION MODIFIERS. I have been using that stuff for 20k miles or so with no problems.
  17. Taco15
    Tallahassee Fl
    thanks man
  18. pissedoffsol
