The dyno reads your engine rpms for a reason. Ever notice how you can't get a torque curve without having the engine speed read? You'll just be on a different scale if you don't measure it- you'll have a readout vs speed, and the speeds may be different depending on what gear you chose, but you won't get a torque or hp vs rpm graph. If you are reading the engine speed, then gear ratio doesn't matter.
