Gear Ratios VS MPH for B-series Tranny's
Discussion in 'General Tech and Maintenance' started by khai_tuan_nguyen, Dec 15, 2003.
  1. khai_tuan_nguyen
    khai_tuan_nguyen Senior Member
    How can I tell what tranny I have. I was told it was an LS, but when i am at 70 mph my speedo is at 4000 rpms. Is there a serial etc on the tranny I can look at?
    Yes my tires are the correct size and the rpms are correct.
    Thanks
    Khai
  2. E_SolSi
  3. khai_tuan_nguyen
    That is exactly why i am confused. By looking at that chart it says i do not have an ls tranny. Does anyone else have a b20 vtec with ls tranny and at 70 mph in 5th gear you are at 4000 rpms?
  4. khai_tuan_nguyen
  5. sleeperls93
    sleeperls93 Senior Member
    I have a b16 tranny and at 70 mph I'm at 3800 rpms
  6. jamesA
    :withstupid:
    I have a B16a2 transmission as well.
    5th gear at 70 mph is 3800 rpm, 80 is right around 4400 rpm.
  7. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    refer to what E said.
  8. khai_tuan_nguyen
    I did look at E's guide that is why i am asking you guys. According to E's guide it says an LS tranny at 70mph in 5th gear is in the low 3000 rpms but I was told my tranny is an ls, but at 70 mph in 5th gear it is at 4000. IS there any way i can tell what tranny i have.
    PS the tires are the correct size and the rpms are right.
    Khai
  9. jamesA
    I dunno if there's any markings stamped on the transmissions. I'm willing to bet its a B16 tranny. What kind of engine do you have?
  10. jamesA
    OH, and what kind of car do you have?
  11. JDMilan
    Boca Raton, FL
    check the stamping on the tranny
  12. jamesA
    I'm sure his next question would be where would the marking be? I know it's in plain site on my old Escort (if you have the air filter assembly out)...but you know honda...doing things all weird and shit...
  13. khai_tuan_nguyen
    It is a b20b with b16 head. 12:1 compression. Yeah that is my next question where is the stamping..
    Khai
  14. Fastciv
    Fastciv Member
    Ohio
    My b16a2 tranny has a VIN tag on it (don't remember which side)...but anyway, I took that number and entered it on carfax. Carfax confirmed that the engine/tranny came from a 2000 Civic Si. This info was provided in the webpage before they asked for my credit card#. Try that.
  15. khai_tuan_nguyen
    Thanks i know what tag you are talking about, but mine does not have it any more. Is it stamped etc. anywhere?
    Thanks
    Khai
  16. pissedoffsol
    sc4?
    y1?
    it should have one of those on it...
  17. khai_tuan_nguyen
  18. khai_tuan_nguyen
  19. khai_tuan_nguyen
  20. khai_tuan_nguyen
