You should flush your coolant once a year. Also every % years you should change your radiator cap, because the seal gets old and worn out. this will cause leaks around the seal and you will loose some pressure on your radiator. In which the result is higher engine temperatures! I say flush it, change the cap(if older than 5 years) then if that don't fix it... Look into the thermostat!
