general swap questions, 91 civic- dohc d16
Discussion in 'HYBRID -> ED-EF / DA' started by 90dals, Dec 31, 2003.
  1. 90dals
    90dals Junior Member
    hey guys, im fairly new on this forum. i noticed a ton of helpful info.
    anyways, i sold my 90 integra a couple weeks ago, and buying a 91 dx hatch (105k) this weekend. im planning a dohc d16 swap.
    i understand that i need a MPFI swap, the engine mounts are same (atleast use the civic ones) and shift linkage is the same.
    now, do i use 90-93 integra axles? from b18a right (As in not the b17 gsr ones, that would be 92-93 anyways).
    do i have to bash in the wheel well to fit the alt?
    what other mods do i need? i know i need a DOHC ecu. which ECUs specifically will work for me? 1g tegs, and 2g tegs?
    anything else i should know?
    thanks in advance.
    Stephen
    Ballistic Performance
    614-262-4176
  2. Jeef
    Jeef NO MA'AM Moderator VIP
    Use your current transmission and axles. Do an mpfi swap and use the zc ecu or an 88-89 5spd teg ecu.
  3. 90dals
    use a DX tranny? not a ZC tranny? why would the DX be better, shorter?
    just wondering, not questioning your judgement.
  4. Jeef
    I thought that you were just changing the engine. If youuse a usdm tranny then you do not have to swtich axles. If you do use the zc tranny then you will need to get custom made axles. I am not sure which combo of axles it is, but the info is all over the internet. The best transmission gearing would be to make a hybrid zc/si tranny. The crx si trany would be the next best, then the zc, then the dx/lx sedan tranny, then the dx hatch/crx tranny.
