Get the Right motor.
Discussion in 'HYBRID -> EG-EK / DC' started by EG8Demon, Sep 8, 2006.
  1. EG8Demon
    EG8Demon 20"s ON MY HONDA
    North Carolina
    Whenever I go to get the engine swap of my choice, how do you make sure you get what you want. I want to get a B18C TYPE R and I want to make sure I get the type r. Where would be the best place to get the motor from. THANKS FOR HELP.
  2. greygoose
    greygoose Junior Member
  3. *crxtasy*
    *crxtasy* New Member
    Ohio
    The type r motor is the b18c5. the gsr is the b18c1. make sure the engine stamp says b18c5. as far as where to get it i couldn't tell you, those engines are a rare commodity that I wish I could find for a decent price.
  4. greygoose
    He wants the jdm type-r thats stamped b18C
  5. crazi_e
    crazi_e New Member
    thats gunna be a tough one..arent the jdm gsr's and jdm type r's the same block code b18c?
  6. florida
    florida Acura 1.6EL Premium
    CALIFORNIA
    ^^No, they are not.
    The JDM Type R is B18C R
    The JDM GSR is B18C
    Florida
  7. *crxtasy*
    Ohio
    ok, I didn't know you wanted jdm. but I'd just go with what florida said, I haven't really researched the jdm market to much yet. but as far as usdm, b18c5 is type-r
  8. crazi_e
    crazi_e New Member
    actually they are.. jdm motors dont have a number at the end of the block code
    JDM: USDM:
    d15b d15b7
    h22a h22a4
    b16a b16a2
  9. florida
    CALIFORNIA
    I swear I've seen pics with B18C R stamped on the block. But after doing some more research I think I might be wrong. Apparently there is only "B18C" on both JDM Type R and GSR.
    Florida
  10. crazi_e
    crazi_e New Member
    good thing you edited your last post..i had a paragraph for you to learn from :D
  11. dthug
    dthug New Member
    jdm trpe r and gsr have the same block code only difference is the internals and valvetrain
  12. *crxtasy*
    Ohio
    Why are the jdm motors vauge in that respect? You would think they would have some way of identifying engines without ripping into them.
  13. crazi_e
    crazi_e New Member
    Dont really understand that myself, but you could most likely tell what motor it is if it is left stock. You can check the oil pan and read what it says p72 for gsr and p73 for type- r. Cam gears as well, just take off the cover and there it is.
  14. tunedhonda-ata
    tunedhonda-ata im turbo bitch!!!!
    D-town
  15. 94gsreg
    94gsreg 94gsreg
    Missouri
    you can also tell by the intake manifold and the code that is stamped on the head itself.
