gettin ready to drop in
Discussion in 'HYBRID -> ED-EF / DA' started by vdubber, Oct 4, 2003.
  1. vdubber
    vdubber Member
    aight, my ? is how good usually are the trannies on the b16a1's. I got mine from nippon motors. I have a replacement clutch, but i was wondering if it would be worth while to swap it out now or drive on the old one. Plus these engine are only supposed to have around 60k miles at the max right?
  2. ConceptSleeper
    ConceptSleeper Member
    La Mesa, New Mexico
    if i were you i would defiantly change the clutch b4 you drop it in! there are not any for sure ways to tell the milage on these engines but they tend to be low considering in Japan they use the poublic transportation system more and its a small island, and taxes are higher or something like that on older cars, i read this in another post in this forum. i would change the timing belt, plugs etc.. as well, hope this helps good luck
  3. mellowboy
    mellowboy Senior Member
    ChicagoLand, ILLINOIS
    I agree ;)
  4. snoman8
    snoman8 Junior Member
    whats up evryone,I got a b16a1 from j-spec autosporsts,to put in my crx dx.this swap fit mint with enjo mounts.my problem now is that I have no spark and don't were to wire the v-tec to.the spark is killing me because i checked all harnesses and ecu.there was a crane cam ignition on it but it was cut (bought car from friend)and need some help.
    :spin:
