I have some good "How to" pictures that will help for sure. PM me any time for a phone number and we can talk.
I just dropped my D15B7 out of my hatch, and installed the B18B... can help with parts needed and if you need it... It took me 8 hours to drop the D series and install the B to safe running...
Serrillion, did you have to find another throttle cable or modify the bracket for the throttle cable? I had to do that on my EK, wondering if it is the same scenario for the EG chassis.
While those brackets look a lot like cast iron, I believe them to be forged steel.The EF mount near timing belt is different than 92-00 Civics. I'm talking about the cast iron mount that actually AT&T he's to the block.
But my point is mute b/c you are in search of a new swap.
You can get an entire OBD1 B16A swap from a JDM engine importer for around $2000
I thought he mount issue was based on the angle that a B series sits in an EF. Every time i see the bay of a B swapped EF, I always thought it was a weird/different angle in comparison to my EG
There's always room for you to come up with a revolutionary way to Levitate the rusted frozen Harmonic Balancer off of it without using a pneumatic impact gun......I'm just picking up another motor that has just under 100k miles on it. Doing the typical waterpump timing belt and so on. But will post pics.
