getting an ls and i have couple questions?
Discussion in 'Engine Building' started by rizq777, Dec 5, 2003.
  1. rizq777
    rizq777 Member
    im getting this ls motor with ecu,axles,stock mounts,wiring harness,but the tranis automatic. what needs to be changed when i get a hydro tranny. would i have to get a different ecu or o2 sensor or what?
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    the ecu will need to be converted to 5 speed.. but you can do that yourself very easily...
    the info can be found on www.hondata.com or at my page
    http://www.hondaswap.com/~pills
  3. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    the two trannies interchange, you also need the shift linkage, oh hell just go to pills link :)
  4. gocivicls
    gocivicls Senior Member
    forest city, NC
    Don't forget to get a flywheel and clutch!
