I drive a 2004 Acura TSX with 61K miles. Up to this point, I've spent $1500 trying to fix the problem over the past 15K miles. I get not so good vibrations that appears at highway speeds. Here's what I've observed.
- Vibrating comes and goes at 64, 69, 73 and 81 MPH, +/- a few ticks.
- Can feel the shaking through the seat a little bit and definitely see the steering wheel shaking L & R.
- Doesn't make any diff whether I'm accelerating, decelerating, in neutral or clutch in.
- Doesn't make much diff whether on asphalt or cement roads.
- Shaking is less noticeable with full tank of fuel.
- Does not pull left or right.
- First appeared and became apparent quickly after a regular tire rotation and balance.
- Will continue to happen even after driving long distances.
- Does matter if it is 40 or 100 degrees outside.
- 8+ attempts to balance tires at three different shops. Even tried 'Road Balance'.
- 2 sets of different tires plus a few one off replacements. None were worn abnormally, but were replaced to try to solve vibration.
- 2 alignments (which didn't show any misalignment).
- Replaced OEM wheels with new Enkei wheels with hub rings.
- The axles have a bad inner CV. However, some people say only should shake when accelerating.
- Sticking brake caliper. However, all the brakes are wearing evenly and have plenty of pad left.
- Warped rotors that are causing them to be out of balance. The front rotors are slightly warped, but what Honda rotors don't warp. I get brake shuttering only at high speed braking and only at certain firm pressure/speed range.
- Sell the TSX and buy a Ford Mustang. Those suggestions are dismissed outright as crazy talk.
