Go Turbo Or Supercharge On Auto Tranny?
Discussion in 'Forced Induction' started by CIVIXER, May 20, 2003.
  1. CIVIXER
    CIVIXER Junior Member
    i WANT YOUR THOUGHTS IF TURBOCHARGER OR SUPERCHARGER WOULD BE BETTER FOR AN AUTOMATIC? THANKS.
  2. pissedoffsol
    a manual would be better for an automatic.
    honda auto's suck. they won't hold much power at all. if you're looking for performance, a tranny swap/conversion shoudl come in your future before boost IMO
    and loose the freakin CAPS
  3. dcsports413
    dcsports413 Senior Member
    what do u mean by a manual would be better for an automatic?????
    A strong auto tranny is good for turbo because you can boost before launch.
    DO ALL CAPS HURT YOUR EYES?
  4. Distorted
    Distorted Member
    Seattle, Wa
    Sure, a strong auto tranny might be good, but Honda auto-transmissions aren't. Besides, where's the fun or challenge in driving an automatic. Automatic sports cars are sacreligious in my opinoin. Whomever made the call to make automatic corvettes, porches, or any other sports cars should be drawn and quartered. Either way, if youwant to boost, you're going to want the manual transmission, dont worry about being able to boost before you launch, when you realize your gear ratio's suck and you have to buy another torque converter, you'l have regrets.
  5. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    careful, he does run this site and he knows what hes talking about. the keyword you said was strong auto tranny, hondas dont have a strong auto tranny to hold a lot of power.
  6. Havok
    Havok Senior Member
    Florida
    Wow. Just...wow. I'm going to be nice, all I will say is that is wrong on so many levels.
  7. dcsports413
    You cant just say i'm wrong. Explain yourself. A Honda auto tranny is NOT going to be strong, a built one is. Many drag cars have 4 spd auto trannys. It all depends on what he wants to do with the car anyway.
  8. Gen2Teg
    Gen2Teg Senior Member
    san francisco
    yea but these r funny cars that run the 1/4 mile in 6 seconds, i don't think they have time to shift, thats y they have automatics. And im pretty sure their auto tranny isn't made by honda.
  9. dcsports413
    this is true
  10. Gen2Teg
    san francisco
    this is VERY true
  11. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    after tw0 blow auto trannys i have now performed 2 auto to manual conversions and am in the middle of number 3
    (up here auto are super cheap and pleantifull)
    the honda auto tranny does not launch well and gives shitty performence and has a nasty habit of ranomly shifting gears and make really lound grinding and tinkiling noises when you add boost to the equation
  12. pissedoffsol
    the problem is, there are little to no parts for performance honda automatics. they are weak from the factory, the gear ratios suck, and there isn't aftermarket support to make them perform.
    auto's by default ARE faster than manuals, due to the faster shifting and the availbility of a high stall converter.
    however, the honda one's suck. there are no high stall converters that i know of. the only b-series auto in the US is an LS tranny which is too long unless you are running 9s. on top of that, they will blow up if you feed them any kind of power.
    as for boosting off the line- hello and welcome to hondata's boost timing retard control- or any other mechanism that allows for an "engine load" to be simulated. I'm planning to leave the hole around 8 psi :)
    and yes CAPS HURTS MY FUCKING EYES and its down right annoying.
  13. YangpaNemsay
    YangpaNemsay Senior Member
    Okinawa, Japan
    If you really are bent on boosting an automatic tranny, use a supercharger. Manual rides are the only type worthy for turbos. Also turbos are generally good for FWD but since you have an automatic you'll be getting boost as soon as you hit the pedal i believe (correct me if i'm wrong).
  14. pissedoffsol
    well, that depends on the size/trim of the turbo
  15. VuDuDuOnU
    VuDuDuOnU Member
    ite this guy is talkin about a civic wuh about an 99 accord? yea its a auto, would it be best and cheaper if i just go with the supercharger or get a h22a? and do shit to the h22a? and how much would it cost for me to switch trans, isnt it $1000+ for the clutch to be added alone?
  16. pissedoffsol
    when you do the h22 swap, it comes with a manual tranny already. you just have to add the other thigns to make it work- the interior consel, the pedal assembly, the clutch master cly, and the hydro lines.
  17. VuDuDuOnU
    VuDuDuOnU Member
    what would your estimated guess be?
  18. pissedoffsol
    depends hoe cheap you can score the above parts at your junk yard
  19. hcivic.com
    I have done a 91 civci auto to manual for as little as 100 bucks inlucding the tranny
    you need the pedal assebely center counsel
    try to gat a b seires cable tranny
    to add the hydor resevoir and lines is alot harder than a single cable
  20. pissedoffsol
    hes doing this to an accord, nto a civic dude...
