Goin from a D16Y7 to D16Z6
Discussion in 'HYBRID -> EG-EK / DC' started by silverboost, Jan 5, 2006.
  1. silverboost
    silverboost Junior Member
    Im swappin my d16y7 to a d16z6, i have a 98 civic. I want to know if theres anything I need to complete the swap. I have the d16z6 with the vtec ecu and harness. Is there anything else? I just dont want any surprises when I do the swap. Thanks
  2. lsturbohatch10
    lsturbohatch10 Member
    Cleveland, Tn
    you will need a obd2 to obd1 conversion harness. the y7 is a great mini me motor tho!!!
  3. silverboost
    i dont think i do because i bought an obd1 harness and obd1 p28 ecu
  4. silverboost
    the thing im worried about is the engine mounts, are they the same?? i know the right mount (by the timing belt) is different on the z6
  5. hosmer
    B R I D G E W A T E R
    he means you'll need the ODB2 to ODB1 jumper harness at the ECU....or to re-pin your ECU connector
    The mounts from the Z6 should work
