Good Enough Specs?
Discussion in 'Engine Building' started by viciousracing, Mar 18, 2003.
  1. i'm building up my B18C head. I have a JG redline series head fully ported and polished with oversized valves.
    These are the specs i will be apply:
    Toda Spec C camshafts (intake and exhaust)
    Toda Titanium Spring and Retainers
    Toda Adjustable Cam gears
    Spoon Rocker Arm
    OEM valve lifters
    Skunk2 Intake Manifold
    I will be running on Mugen P72 ECU. Do you think this application is good enough? I have hondata but i lack the time on tuning it.
  2. 2 litre EG
    2 litre EG Senior Member
    so cali
    hmmm what compression are you planning on running?
    i dont know if the oversze valves will have enough clearance due to the size of the Cam Lobes on the Toda Spec C's
  3. i'm plannin on runnin a 12.5:1 ratio
  4. 2 litre EG
    so cali
    you might wanna check to see if the valve clearance will be enough... over-sized valves are't used all too much anymore
    why did you decide to go with spoon rockers?
  5. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    if you have a hondata .. you can write a better map blind for that setup than the mugen setup
  6. spoon rockers? i really don't know.....what clearance do you mean? valve to rocker? valve to piston? ???
  7. about the hondata, i'm getting old at it, i really don't know what the heck i'm doing with it...too complicated. any suggestions on the hondata?
  8. pills_PMD
    New Albany, OH
    the valve/piston clearance on hte high cam lobe profile
    and for hondata tuning info, click the link in my sig... for hondaswap.com/~pills
    then go to the hondata tuning page
    what stage hondata do you have//
