got a few questions
Discussion in 'Engine Building' started by 93vicb16a2, Feb 1, 2007.
  1. 93vicb16a2
    93vicb16a2 WHATS CRACKIN??
    bfe
    i have a b16a2 and i want to do a lil to it it is all stock
    the only bolt ons i have is dc sports 4-2-1. rc 310's, full exaust, cai, msd external coil and 6al bax, aem fuel rail and reg.
    is it worth the $ to buy a aftermarket intake or should i just stay w/ the b16 one?
    i have gsr cams should i use them or should i get type r or skunk 2
    i want to run nitrous (75 shot maybe)
    and not turbo yet
    all this is going into a 90 hatch
    thanks for all the answers
    and i am sure i will have lots more questions
  2. ThatGuy4life
    ThatGuy4life The Riced Sleeper
    Albuquerque, NM
    Aftermarket intake a plus
    if you got the money go with the skunk2
    i'd stay with a 50 shot instead of the 75
    Keep in mind this is all personal preference
  3. 93vicb16a2
    bfe
    why would u not go with a 75 shot??
    witch stage skunk 2 cams are better for a dd
  4. get_nick
    Washington State
    if you must have nitrous, either is fine. the bigger the injection the shorter engine life you will have.
    skunk2 stage 2 at most for dd. but you will need to upgrade the rest of the valve train. stage 1 you can keep your stock valves and retainers.
  5. ThatGuy4life
    Albuquerque, NM
    Nick already answered no need for me to repeat what he said
    but let me add you can also go with the pro 2's for a dd but you have to have a hell of a tune
  6. get_nick
    Washington State
    if you get too much of an aggressive cam, you won't have high enough compression and you will need a lot more headwork also. you will actually be just wasting money on more expensive parts that aren't utilized. it would be like putting a t66 turbo on a stock honda block. it would work, just not to the ability of the turbo and would actually make your car suck.
  7. ThatGuy4life
    Albuquerque, NM
    whoops my bad, I was thinking about my build when I made the last post, forgot he just has the stock B16
  8. 93vicb16a2
    bfe
  9. 93vicb16a2
    bfe
    does any one have a opinion on aftermarket intake manifold or stock??
