got a gsr question...
Discussion in 'Engine Building' started by auth3nt1c, Mar 1, 2009.
  1. auth3nt1c
    auth3nt1c New Member
    would it be possible to use a gsr obd1 block w/ obd2 head? would i encounter any problems between these two? :confused:
  2. Matts96HB
    Matts96HB . Moderator VIP
    Yes it is possible. You'll need everything on the head to be OBD1, and the ECU will need to be OBD1. It needs to match the distributor, basically.
  3. auth3nt1c
    when you say everything on the head to be obd1, you mean the sensors?:confused:
  4. Matts96HB
    Well, pretty much just the dizzy lol. Is the car OBD1 or OBD2?
  5. auth3nt1c
    the car is obd2...so it should just plug and play! okie dokie thanks...
  6. Matts96HB
    Yeah as long as you have an OBD2 GSR ECU and dizzy you should be alright.
