got a new tach
Discussion in 'ECU's, Electronics, and Tuning' started by rex187, Aug 8, 2005.
Thread Status:
Not open for further replies.
  1. rex187
    rex187 Member
    austin,texas
    alright today i bought a new autometer tach. i was wondering if anyonw knows how to put the tach in to a 91 crx si b16. it came with wirring instructions but they make now sence what sort. any help would be nice. thanks
  2. rex187
    rex187 Member
    austin,texas
    ok i have power to the tach...but i cant get it to read the rpms. i dont know what wire to put it to.. do i need to cut the blue wire that gose from the stock tach to the dis. and take this grean wire on the new tach and comebine it with the blue wire? does anyone know how to do this it would really help
  3. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    I wired mine into the blue wire that goes into the dist.
    EDIT: Splice it in, don't cut it, then you can have 2 tach's :lol:
  4. Celerity
    Celerity Well-Known Member
    You have a stock tach ? Or the tach wire as described in the manual ?
    As I recall it's the blue wire on the distributor, I spliced it and away I went. I have the old dizzy in a box if you wanna see it.
    And today, apparently, I ate my 4th distributor.
    -> Steve
  5. drpenguin
    drpenguin Senior Member
    Salem, Or
    just get a wire tap and tap the blue wire going to the back of your stock tach. they will both work then. if you want you can run a wire all the way out to the dizzy if you like
  6. fasterimage
    fasterimage 2 SLOW CREW
    State College, PA
    hey yall, I was just curious...I just picked up an autometer 5" tach with the memory function and there are four wires. red, Black, White,Green, what are the 4 wires for....red and black im guessing would be power and ground, and the green for the tach signal, what is the white wire for, I bought it out of a race car at a junk yard...so I dont have hte instructions? plzz help
  7. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    thread from the dead, and not even on topic. good job.
  8. 97hatch
    97hatch ?
    Anderson IN
    its only a year old and its close to the topic :ph34r:
  9. Vtecmonster08
    Vtecmonster08 Vtecmonster
    Las Vegas
    the tach reads 2500 rpms when the car is on idol? Help..
  10. Korax
    Korax New Member
    Western PA
    Start your own thread man, this one is from 2005. and was already bitched about reposting in it a year after the fact. Reading is fun^^/.
Thread Status:
