Got A Question
Discussion in 'General Tech and Maintenance' started by TRuggiero_, Feb 12, 2003.
  1. TRuggiero_
    TRuggiero_ Senior Member
    Winter Garbage, Fl
    So I came home, went into my house, came back outside 5 hours later and my brake lights are on, it died so I jumped it. E-Brake wasn't on, nothin else, just my brake lights, I pulled off my battery cable for now, but what the hell is wrong with it?
  2. E_SolSi
    :blink: hmmmm.... maybe the brake pedal isnt coming up all the way??? or something electrical????
  3. RFHOMI2U
    RFHOMI2U Senior Member
    check the wiring on your tailights. maybe something is shorting out? thats what happened to me before.
  4. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    there is a little switch that is activated buy the brake pedal being pressed the best dolution is to replace the switch or if that is not an option then glue a washer to the to of it and it will be fixed
  5. TRuggiero_
    Winter Garbage, Fl
    Alright, thanks guys, I'll try checkin out the switch thing when I get home from school.
  6. TRuggiero_
    Winter Garbage, Fl
    By the way, it was this little peice of crap plastic thing that hits the button for the lights, it shattered, thanks for all the help guys.
