got general questions and need answers
mref80891
if there's anyone who can help me. just need someone to hear me out and not make like im dumb. also please feel free to be a friend.
so i recently had a head gasket problem. and i wanted to noe if i would need to check my engine to see if oil got push back into the engine and would i need to flush it out? also where can i find performance head gasket kit thats made for my engine which is a b16a motor.
if you lost a HG, you should change your oil and your coolant. Those are the 2 systems that would have 'combined'. A flush of both = a good time.
you don't really need a 'high peroformance' head gasket, and i wouldn't recommend one if you aren't planning to re-tune as they can effect compression ratio. a stock oem replacement should be fine for nearly all 'street' cases.
