got it running
Discussion in 'Civic and CRX - EF' started by DESPAIN, Dec 18, 2008.
  1. DESPAIN
    flower mound TX
    ok hee is the question. will it throw a cel if the o2 sensor is not hooked up right? and will vtec still engauge if the o2 sensor is not hooked up right? also how do i check to see if vtec is engauging? any help is mucho appreciated....:confused:
  2. t3t4delsol
    t3t4delsol New Member
    York, Pa
    yes it will throw a cel, and you car will run like ass, It needs to be hooked up. period
  3. 96ekhatch
    96ekhatch New Member
    To find out if vtec is engaging you could just rev it up with the throttle body and put your finger on the vtec selinoid at the same time and if you feel it like click then vtec is engaging.
    1 person likes this.
  4. LILBLKCRXSI
    LILBLKCRXSI New Member
    yes the vtec will engage fine if the o2 sensor isn't hooked up; also You should be able to feel when the vtec kicks in for sure lol, please rep if it helped!!
  5. George777
    George777 ^^ Likes Bewbies
    With your mom
    Why are all the noobs begging for rep? Been noticing that a lot lately.
  6. hondasaurus
    hondasaurus Member
    VA/DC
    i think he wants negative rep
  7. 96ekhatch
    I know alot about that kind of rep!! lol
  8. DESPAIN
    flower mound TX
    Where do i find info on the red line for the d16 head thats on the car?
  9. DESPAIN
    flower mound TX
    D16Z6
    • Found in
      • 1992-1995 Honda civic SI
      • 1992-1995 Honda Civic EX, EX-V
      • 1992-1995 Honda Civic ESi (European Market)
      • 1993-1995 Honda Del Sol Si (US)
      • 1993-1995 Honda Del Sol ESi (European)
        • Displacement : 1,590 cc (97 cu in)
        • Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
        • Compression : 9.2:1
        • Power : 125 hp (93 kW) @ 6600 rpm & 106 ft·lbf (144 N·m) @ 5200 rpm
        • Redline : 7300 rpm
        • Fuel Cut : 7411 rpm
        • Valvetrain : SOHC VTEC
        • Fuel Control : OBD-1 MPFI
        • Head Code : P08
        • ECU Code : P28
    IS THIS RIGHT? EVEN THOUGH ITS A D15B BLOCK?
  10. LILBLKCRXSI
    h i'm sorry your highness, i figured i'd try something new, but hey rep is rep good or bad;) not like i care:eek:.
    oh i see , thanx dik.
