Got my motor!!!
Discussion in 'HYBRID -> EG-EK / DC' started by RFHOMI2U, Dec 20, 2002.
  1. RFHOMI2U
    RFHOMI2U Senior Member
    I just got my d16z6 today for my 90 crx si. Ran into a little bit of a problem. The wiring harness doesn't plug in to the connectors near the fuse box. I'm planning on ghetto rigging the vtec using a fields afc vtec controller, a auto relay, and a rpm switch, but how do i plug the wiring harness into my ecu??? the plugs don't match!!! i'm confused. I could really use the help, i can't find it anywhere.
  2. Havok
    Havok Senior Member
    Florida
    Hope this helps
    Wiring diagram for MSD rpm switch part #PN8950 and an MSD module selector part # PN8670 with 30 amp 4 wire automtive relay:
    Red Wire-------------------------12 V source
    Black Wire-----------------------( - ) Ground
    White Wire----------------------( - ) Side of the ignition coil ; splice or conect to ECU pin B15 or B17
    Yellow Wire---------------------# 86 on the relay ; you have to cut the two loop wires
    30 amp relay
    #85 ------12 V source
    #86-------Yellow wire form the rpm switch
    #30-------12 V source
    #87-------Vtec solenoid (green and yellow wire)
    #87a-------Not used
    Field SFC vtec controller for 88-91 crx application : vtec controller ECU pin location
    Red wire--------splice/connect to A15 (yellow/black)
    Green Wire-----splice/connect to B15 (white)
    Dark Blue-------to vtec solenoid
    Yellow-----------not used
    White/green---not used
    Purple-----------cut/connect to B16 ecu side (white/red)
    Light Blue------cut/connect to B16 engine side (white/red)
    Orange---------cut/connect to C11 ecu side (white)
    Brown----------cut/connect to C11 Engine side
    Black-----------( - ) ground
