joesefcivic
ok we finally got my motor in my car got it all done and started up. after two turns of the key it started right up. ran awsome. no smoke no nothing thing runs like a champ. well while it was in the air we decided to see if it would go into gear. well 1, 2 went in fine. but 3 was a little rough. but for some reason the clutch will not disangage. while the car is in the neutral position the wheels will just spin. and if i hit the brake with the clutch pedal up the car will stall out. so what should i do. i have one week before i need to have the car up and running well.
could it be the clutch assembly in wrong.
the clutch cable is the wrong one.
the linkage is messed up.
or what do you think. im not sure, but i would like to drive it this week. if any one can help that would be great. thanks
