Got Two Harneses Need One
Discussion in 'HYBRID -> EG-EK / DC' started by acuramike, Jan 22, 2003.
  1. acuramike
    acuramike Junior Member
    Brandon Fl
    ok i have an 93 integra Ls and i just put a sir2 motor in i used the ls harness with the del sol b16 vtec ecu and it woulded start it turned over and really wanted too and almost did i also have the complete engine wire harness for b16 some of the wires and pugs were differnet on the Ls
    WHICH HARNESS SHOULD I USE LS ENG/WIRE/HARNESS OR
    B16ENG/WIRE/HARNESS
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Capitalization,periods,commas,and grammar would help.Do you have fuel,fire?If so check your timing.
  3. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    correct answer...both use the LS harness and plug it into motor and use the B16 harness to hook up all the VTEC stuff...
  4. acuramike
    Brandon Fl
    its got spark it's got plenty of fuel and yes its in time. the new motor come out of a runnig car and was put in
  5. xj0hnx
    C.C.TX.
    Then check all your grounds,but if the starter was turning it could be a weak battery.
  6. tomtom
    tomtom Senior Member
    central, cali
    if u got spark and fuel all ur missing is ___________
    i think someone got swindal
    just make sure u pull the plugs out and look at them
    double check ur fireing order too 1342
    and make sure number one is at number one on dist. cap
