govenor on a p73 jdm?
Discussion in 'ECU's, Electronics, and Tuning' started by 96IntegGSR, Mar 28, 2004.
  1. 96IntegGSR
    96IntegGSR Member
    San Diego, CA
    i just did a b18c type r swap on my integra. when i was driving home it appeared ot have a govenor at 130 mph!!! how do i get rid of this. someone told me that adding a field sfc vtec controller would do it. is that true? please help.
    thanks
    jon
  2. cycloneb18c3
    cycloneb18c3 Senior Member
    New Jersey
    a vtec controller in no way shape or form change your speed limiter. The only way you can change it is to chip your ecu.
  3. 96IntegGSR
    96IntegGSR Member
    San Diego, CA
    my friend with a del sol said that his field vtec sfc controller killed his gov. if i have to chip, which chip should i go with to kill the gov, but not mess with vtec or redline?
  4. dohch22a4
    dohch22a4 Senior Member
    Spokane, WA
    First of all, if you have a JDM ECU, your governor will be set at just about 112 mph, aka 180 kmh. Mine kicks in @ 118 according to my speedo, but really, it's 112. Sounds like you've got a USDM unit.
  5. 96IntegGSR
    96IntegGSR Member
    San Diego, CA
    ok, but how do i get rid of it?
  6. radnulb
    radnulb Senior Member
    Sinsinnaty, Ohio
    see response on PGMFI. There is a device designed by a forum member that does exactly what you want. No one has made PCBs/kits/finished devices yet that I know of, but it would be trivial to do so.
    OBD2 ECUs are $$$$ - $$$$$ to chip right now, IF you can even find someone with the blank chips that aren't bunk or fake. Chipping is not the answer here, IMHO.
    http://pgmfi.org/phorum/read.php?f=70&i=833&t=833
  7. 96IntegGSR
    96IntegGSR Member
    San Diego, CA
    that's actually my post but i really didn't understand what option 2 was
  8. radnulb
    Sinsinnaty, Ohio
    I reposted links to the orignal threads on PGMFI... Dunno if you looked at those.
    A guy created a device that gets spliced in between the VSS and the ECU. Up to a certain point, it just copies the VSS signal in to the VSS signal out. Past a certain point (I think it was 170 kph ~102mph) it simply keeps sending the same speed (170kph) instead of your actual speed. This is a much better approach than sending a bogus signal all the time because any ECU functions that are dependent on speed will be upset. Bottom line: ECU functions like it is supposed to, but never sees a speed above 170kph and never hits the fuel cut. Total parts to build: <$10
  9. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    assuming you have a 96 GSR, I would run a p28 with ITR maps.
  10. 96IntegGSR
    96IntegGSR Member
    San Diego, CA
    just put a b18c jdm itr motor
    what's the difference between the usdm and jdm p73 ecu? is there a difference in size or id code?
  11. radnulb
    Sinsinnaty, Ohio
  12. cycloneb18c3
    New Jersey
    and oh yea ur friends full of shit. thank you.
  13. 96IntegGSR
    96IntegGSR Member
    San Diego, CA
    oh and he isn't full of shit. read here:
    The Field VTEC controller is a perfect suppliment for VTEC Acura/Hondas. The Field VTEC controller features an 8 step fuel controller (+/- 30% in 1% increments), a VTEC controller adjustment(2000-9900rpm in 100rpm increments), a tachometer display with shift indicator and a speedometer with speed limiter remover. This unit is dyno proven with impressive results. 1.8DOHC 5-9hp, 2.2DOHC 9-17hp, 1.6SOHC 3-5hp. Perfect for the serious enthusiast! Note: For 4 cylinder VTEC engines only.
    Field now offers a wiring harness to make installation of the popular Field SFC VTEC Controller a breeze. This unit is available for OBD1 and OBD2 vehicles. These vehicles must also be VTEC equipped, because the harness wiring is specifically desinged for the VTEC Acuras and Hondas.
    http://www.inlinefour.com/fielvteccon.html
    thanks
    jon
