chasing a run is damn near impossible with clearcoat....can it be done yes but only in certain areas will you be able to achieve it well otherwise you will end up with more runs
you should never run clearcoat multiple thin coats that won't run. as for chasing a run if its halfway don the car all you do is simply lay on the paint super thick below the run and then keep spraying untill the run starts to move the stop
