Greddy exhaust help
HatchSpeeD
...Hi...
This sort of a hybrid swap question so hopefully this is posted in the right place... :mrgreen:
I need to know if anyone has tried to use a greddy sp exhaust from a 94+ integra sedan on a 92-95 civic coupe? Before I unbolt my exhaust & try was curious if anyone attempted this & what is the fitment issues if any? I know the part #'s are different for integras & civics but everything is so similiar it can't be too bad.
it kinda fits... bill had one on his hatch... the rear LCA hit the exhaust all the time
and he had a test pipe not a cat so im not sure about fitment in that area
so in short yes it can be modified to work... but no its not a direct bolt up
Nice, thx for the response. I had a feeling the problem will lie with the LCA clearance. Guess will have to see what happens. Maybe it will fit a little better seeing that mines is a coupe & his was a hatch. If not mistaken, the civic coupe/sedans have a slightly longer wheelbase, no?
if you got a sawsall or a chop saw and a welder strong enough to weld stainless steel, you'll be fine
