thanks, i will be running t3/t04e, plannin on about 400 crank hp, so will probably go with a spearco if greddy type 31 will only handle 250 or so
thanks again
pressure drop and flow are about the same... its the actual cooling process that is better. i saw a chart a while back... i'll see if i can find it again..
