Greddy Oil pressure gauge question
Discussion in 'General Tech and Maintenance' started by 94CivicSlow, Jun 18, 2005.
  1. 94CivicSlow
    94CivicSlow Senior Member
    B0ST0N
    I am going to use the Greddy oil pressure gauge on my 95 LS.
    I removed the factory oil pressure dummy light switch, am I going to have problems with the cluster oil light on or vtec not engaging because it thinks theres no oil pressure???
    I plan on leaving the factory oil pressure switch disconnected... Has anyone had experience doing this???
    Thanks
  2. 94CivicSlow
    B0ST0N
    anyone
  3. NoJokE
    NoJokE Senior Member
    Nope, you won't have any problems at all.
    The stock dummy light is a one-wire ground signal. When the oil pressure gets to a very low level, it grounds and sends the signal to the dash.
    It won't hurt anything taking it off completely.
