calmfornow
System Failure Racing
ok so i need opinions...92 accord 5 spd. we go to put it in reverse and it grinds when we release the clutch, if i fight with it for a while i can get it to go into reverse and move in reverse for about 4 feet max than it grinds and obviously stops moving. i dont know if it is the shift linkage or the blocker rings in the trans. it is REALLY TIGHT going into first and second a lot also, and when in neutral it is very tight when you move it towards the right side, any help would be great.....thank you
