Ground Control VS Skunk 2 coilover
Discussion in 'Wheels / Suspension / Tires / Brakes' started by redwidow, Mar 16, 2004.
  1. redwidow
    redwidow Member
    Between the GC and Skunk2 coilover, Which one is stiffer?. i am running Tokico HP with Skunk2 coilover and it bump too much. i can feel every road imperfection and i am on stock tires. i don't know the problem cause by Skunk2 or Tokico HP. i am thinking of replace Skunk2 with GC. Do you think that will solve? Thanks
  2. E_SolSi
    go look up the spring rates
  3. dohch22a4
    dohch22a4 Senior Member
    Spokane, WA
    The only "bolt on" solution for this problem is koni yellow shocks. they are the only replacement shock that is valved aggressively enough for the skunk2 springs rates. i believe ground controls can be had with custom spring rates.
  4. pissedoffsol
    yeah, replace the shocks. the coils are too strong for the weaker hp damper
