grs pistons in my ls block question
Discussion in 'Engine Building' started by ls_vtec_b18a1, Oct 10, 2002.
  1. ls_vtec_b18a1
    ls_vtec_b18a1 Junior Member
    i want to put grs pistons in my ls block for my ls vtec. just woundering is this a good combo. if so what will my compression be and what rod do i use the ls ones i hope. ;)
  2. khan
    khan Village idiot
    Tempe AZ
    read the FAQ!
    compression... 10.0:1 - P72 GSR Pistons
  3. paragus
    paragus Senior Member
    do you mean GSR not GRS??
  4. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    They won't fit the LS rods. And I don't think they will yeild 10.0:1 on a B16 head, more like 9.8:1(the GSR gets some of its compression from the smaller combustion chamber). Get B16 pistons. They yeild about 11.2:1 with the B16 head and the fit the LS rod. You cannot use GSR/ITR pistons on a stock LS rod, you have to have them shaved, but B16A/B pistons fit. Be careful with CTR pistons, the yeild something like 12:1.
  5. khan
    khan Village idiot
    Tempe AZ
    i got it straight from the faq...
  6. lsvtec
    My bad you are right.
    They still won't fit w/o modifications.
  7. ls_vtec_b18a1
    thanks for all the infor and my bad i meant gsr not grs its just one of those typing to fast errors sorry. thanks alot
