gsr axle problem.. HELP!!!!!!
b18civic74
just droped a gsr in my 2000 ek and the axles are are at a very harsh angle and willnot let me accelerate around turns without blowing the axles.. the swap has a b16 tranny on it... maybe because im running gsr axles???
thanks for your help in advance
i had the same problem with my 95 civic with b18c4 driveshafts what i recommend is from the engine sides both side cv joints tke them off and check the bearings make sure they aint got a square piece on them if they have go junk yard get sum bearings off a 95 civic the engine side cv join bearings and use them
the square pieces on the bearings restrict the joints from movement i replaced the bearings and its perfect now it doesnt break the bearings now coz there is no square pieces on the breakings il get a image for you to try showing you what the bearings look like
