GSR blocks have ???piston squirters???
Discussion in 'Engine Building' started by jdmking, Feb 24, 2004.
  1. jdmking
    jdmking Junior Member
    I have heard that the GSR blocks have ???piston squirters??? and that the LS blocks do not and if you want a real rev happy motor then the GSR block is the only way to go in the B series motors...Is this true or false???? thanks
  2. projectxspeed
    projectxspeed Senior Member
    New Hampshire
    between those two yes the b18c would be a much better choice than the LS. But if you want a rev happy motor you want a b16, it has the ability to rev higher and harder than the b18c cuz of the stroke.
  3. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    welcome to honda,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,bitch.......
  4. JDMilan
    Boca Raton, FL
    forgot to add :chappelle voice, rick james: when post that up top, meant to be a tad funny.
  5. jdmking
    to Milan:Its all good biiiaaaatttcchhhh!!!!!!!!!! :D ,,,,and to Project, I plan on overboring and stroking a B-18C, I have decided against the H22 swap for now...
  6. JDMilan
    Boca Raton, FL
