gsr brake upgrade
Discussion in 'Wheels / Suspension / Tires / Brakes' started by cloverwood, Dec 24, 2002.
  1. cloverwood
    cloverwood Senior Member
    okay i've decided to get one piece brembo blanks and axxis ultimates, steel braided lines. I still need to decide what to do about the calipers. I'm definently not trying to break the bank but i'm not buying APC stuff either. Also do i need to upgrade the master cylinder or any other of the braking components.
  2. civicracer901
    civicracer901 Senior Member
    Clearwater,FL.
    no you dont have to replace the MC. or booster Its not really a noticable differnce. I did one on a 92HB. It works just fine with or without it. You will have to replace that old ebrake cable with a 94 or higher integra. The ones on the 92 are to short. Thats about it. Just the e-brake cable. You could just get the whole swap from importautosalvage for like $250 thats everything to do the whole swap. Then go from there if you want special things like rotors. steel braided lines arent really anything, You can just keep the stock ones they work fine. I belive that there is a article of rear disk brake swap. Not sure which car your talking about swapping disk onto here.
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
  4. cloverwood
    i already have a gsr so i have discs all the way around thats not what i'm talking about
  5. lsvtec
    Go to one of the two links above, you won't be dissapointed. Trust me.
