gsr tranny in my crx. Speedometer cable seemed to be fine but I replaced it anyway. I pulled the the VSS out, put the cable down it and spun it with my drill and the speedo worked so everything is apparently working from the cluster all the way down to the tranny. I jacked the car up and spun the wheels but I can't feel the gear that drives the speed sensor move at all. It has to be a problem inside the tranny, correct? How complicated is this to fix?
