GSR cluster into EF with GSR swap.
Discussion in 'HYBRID -> ED-EF / DA' started by tcpappas, Apr 17, 2010.
  1. tcpappas
    tcpappas New Member
    I was using google and using search and found all of the wiring to put the cluster into the EF but they all speak of installing the GSR VSS into the transmission in the car. I have the GSR swap so the VSS is already in that transmission so what do i do to wire it to the gauges as well as the ECU? Basically looking for a pinout on the transmission plug for the VSS
    Thanks in advance,
    Tom Pappas
