GSR Clutch Fork Keeps Breaking!!!
Discussion in 'General Tech and Maintenance' started by RFHOMI2U, May 13, 2004.
  1. RFHOMI2U
    RFHOMI2U Senior Member
    My roommate has a 94 del sol with a B18C1 swap. About a month and a half ago, we had to replace the clutch fork (a lever that transfers power from the hydro system to the actual clutch itself) that broke in half for some reason. It's starting to bend and break again. We cannot figure out why. Does anybody know the cause of this problem? We'd rather not pull the transmission and fix it again, it was a bitch and a messy job.
    - Thanks, - Ryan
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    i assume you had the throwout bearing properly secured in there?
    thats very strange.. i haven't heard of anything like that
  3. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    did you make a post about this before? Someone else had this problem too.
    What pressure plate is he running?
  4. nfn15037
    nfn15037 Senior Member
    Is the clutch adjustyed properly? If the rod is too far extended out of the master cylinder it will move the arm too far. This can kill the clutch, or as you have found, break the fork. The Helms has the proper procedure for adjusting it.
