Gsr Conversion
roach009
Member
i need to know what i need to put the wiring and ecu perfect in a 93 civic hatchback cx. i heard i would need adapter of some sort please give me any help. or is it just plug and play
I'm having the same problem, some one told me we can run direct wire from vtec,and the knock sensor to the ecu, just to pin piont the ecu
You will need to add a few wires.
VTEC pressure
VTEC solenoid
Knock Sensor
O2 sensor heater wires & grounds
IAB wires
Other than that, it's plug and play. No adapter necessary.
