Gsr Ecu's?
nash
hey, about gsr ecu's do they change alot from years.? like 94-98? and 99-2001 ? the reason is because i going to drop a b18c1 into my 99 si soch civic coupe, and i wanted a 1999 new motor. Dude told me the wirng is different on 99 gsr b18c1 vs any older motor cause something to do the the computer. is this true? is their a difference between jdm vs usdm in the question? which b18c motor would be best for my project???
please help, thanks in advance! :D
lates
nash
it is.
civics changed in 99 to OBD2b
however, tegs didn't do so until 2000.
usdm/jdm doesn't matter
getting a 2000 gsr will be easier
ok, that because earilier motors are odb1?
what kind of extra wiring is needed to swap a 99 or sooner in my civic?
there are two versions of obd2
>92 obd0
92-95 = obd1
96-98 civics, 96-99 tegs obd2a
99+ civics, 00+ tegs obd2b
using a 2b motor in your 2a car require some more wiring depending on what you have for wire harnesses and ecus
>92 obd0
92-95 = obd1
Let me elaborate a little on this.
As for the GSR it goes as follows:
92-93 is OBD1, but it is a P61 which is VERY similar to the P30 from the delSol of 94-95
94-95 is also OBD1, and is nothing like the previous years because the new GSR had a dual runner manifold (P72)
96-99 is OBD2
00-01 is OBD2b and has the immobilizer in the ECU.
HTH.
so do 99 b18 c 1 have the immobilizers in the ECU's?
from the posts they apply to both jdm and usdm right?
No, the 96-99 does not have it, BUT the 96-99 will NOT plug in a 99-00 (OBD2b) Civic harness.
You need the 00-01 (OBD2b) GSR ecu.
