GSR engine into 98 civic with LS engine/trans already
Discussion in 'HYBRID -> EG-EK / DC' started by philyphreak2127, Aug 2, 2013.
  1. philyphreak2127
    philyphreak2127 Back in the Game
    Littleton, co
    Okay so does anyone know what if anything (besides wiring vtec/ecu) that would need to be changed when swapping a gsr engine into a 98 civic with an ls engine and trans already? I do not know the exact year the engine we are swapping in or the year of the engine in the car already have yet to look at it in person.
  2. Matts96HB
    Matts96HB . Moderator VIP
    Should be a bolt in affair. Just wire up VTEC and a knock sensor as needed
  3. E_SolSi
    also will need to wire up the secondaries
    other than that you already did everything necessary
  4. philyphreak2127
    Littleton, co
    Okay so got some more details. The LS engine is and obd2 97 to be exact, as is the harness and trans. The GSR engine however is an obd1 from a 94 I believe. However my question is without having seen the car in person yet, can we use the obd2 LS harness still, find an obd2 GSR ecu, and distributor and pretty much as stated before wire in vtec and the knock sensor(also looking into rywire subharness)?
  5. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Been a while since I even thought about mix and matching Hondas BUT I'm listening to the Ramones atm so what can go wrong?
    Use the injectors from the LS, find an OBD II (vtec? don't remember if it's the same as the LS) B series distributor, and ECU, run the wires for the IAB's, vtec and go.
