mine didn't come with cable. You will need the GSR cable and GSR fuel line from filter to fuel rail. Magestic Honda online parts is cheapest place I could find. The crv a/c bracket is alot cheaper. are u getting obd2 motor? If so the Jdm ecu will plug into your obd2a harness and Jdm engine will only have one o2 sensor and no Vtec oil pressure switch to wire. All you will have to do is 3 wire to 2 iac change, Vtec wire, knock sensor, and extend a few stock plugs.
