GSR HEAD and tons of other b series stuff
Discussion in 'Parts: For Sale/Trade/Wanted' started by SoSlo, Feb 24, 2007.
  1. SoSlo
    SoSlo Member
    nor cal
    gsr head complete minus valve cover and cam gears____________$350
    jdm b18c crank (need to be polished has 1 spun rod bearing)_____$50
    ls water pump(used)_______________________________________$10
    ls timing belt(used)________________________________________$10
    b series oil pickup_________________________________________$15
    b series coolant tube with thermostat housing(used)_____________$20
    b series idler pulley(used)___________________________________$5
    b16 tranny brace_________________________________________$5
    obd2 crank angle sensor___________________________________$15
    obd 2 timingbelt crank pulley(chipped)________________________$5
    obd 1 timingbelt crank pulley_______________________________$15
    vx (13/16) brake master cylinder____________________________$5
    gsr head bolts___________________________________________$15
    gsr crank pulley___________________________________________$25
    3 usdm gsr pistons with wrist pins____________________________$10
    2 jdm gsr pistons with wrist pins______________________________$5
    drive side eg manual mirror___________________________________$5
    srs computer_______________________________________________$15
    complete engine bay fuse box_________________________________$20
    empty ecu case_____________________________________________$10
    ls crank case breather box____________________________________$10
    gsr crank case breather box___________________________________$10
    gsr engine header bracket____________________________________$5
    black charcole box___________________________________________$5
    gsr fuel pump_______________________________________________$10
    5 bolt turbo exaust flange_____________________________________$10
    2.5"-3" turbo coupler________________________________________$5
    2.5" t-clamp_______________________________________________$5
    3" t-clamp_________________________________________________$5
    92-95 oem headlights with turn signals, one pracket broken________$10
    obd1 coolant temp sensor(block)______________________________$5
    b series coolant thermostat housing and tube____________________$15
    4 oem b series wrist pin______________________________________$5
    new pics comming soon
    everything is OBO
    i am paypal certified
    hit me up at smmccurdy@hotmail.com
    have pictures for serious people
  2. Reckone
    Reckone EF aholic
    Albany, NY
    Intersted in the 5 bolt turbo exaust flange. Any pics of it? Let me know how much shipped to Albany, NY 12206.
  3. eg6sir
    my offer stands on the corners
  4. delsolh22
    delsolh22 New Member
    Do you still have the distributor OBD1? How much if you still got it?
  5. prdsmracer03
    prdsmracer03 New Member
    Will you do 250 on the head, and were u located.
    LJ
  6. jdmcivic007
    jdmcivic007 New Member
    DuRTY JeRZeE
    what's good with that head.. n where u located at??
  7. BIGBADD15
    BIGBADD15 New Member
    how much to ship head to 37062
  8. JDM__EK9__510
    JDM__EK9__510 New Member
    Newark,CALIFORNIA
    wher u at?
    let me know wut part of Norcal u live? let me know..... my bro and my homie need a gsr head:D
