Gsr help
Discussion in 'Engine Building' started by blewup91rex, Apr 16, 2008.
  1. blewup91rex
    blewup91rex New Member
    I have 2 problems and need help...i was changing my header the other day and one of the bolts going into the head broke how can/should i fix it?...And the other is that i changed my vtec silanoid gasket or however you spell it and over torqued the bolts so now its leaking how do i fix either of these problems Thanks
  2. blewup91rex
    come one please
  3. newb
    newb phresh VIP
    Backwoods Northwest
    Try an Easy out on your header bolt. Its gunna be a bitch no matter what you do, but get a can of penetrating lubricant (at an auto parts store, itll say right on the front of it that its for header bolts) and soak that thing. Be generous with the lubricant, and give it time to penetrate, and thatll help.
  4. blewup91rex
    thanks alot ill give it a try
